Aorus Radeon RX 570 Review
May 19, 2017 | 12:53
Tags: #polaris #radeon
Companies: #amd #aorus
Aorus Radeon RX 570 Overclocking
The Aorus Engine utility gave us no control over this card's power limit, which is odd. The option was there in Radeon WattMan, however, and we set it to the maximum: 150 percent.
No voltage increase could be applied to the core either, and in the end we only got the card stable at 1,355MHz, which is some way off the 1,430MHz we saw with MSI's Gaming X card. It is, however, always a lottery. The overclock is 75MHz (six percent) higher than the out-of-box frequency, or 111MHz (nine percent) over reference clocks.
The memory did appear to let us increase the voltage, at least in WattMan. Using this, we set a voltage of 1,000mV (100mV more than the 900mV default) and reached 1.95GHz (7.8Gbps effective), an 11 percent boost.
Overclocking - 3DMark Fire Strike Extreme
1,920 x 1,080, DX11, default settings
  • Asus Radeon RX 580 Strix Gaming Top OC 8GB
  • Sapphire Radeon RX 580 Nitro+ 8GB
  • Sapphire Radeon RX 480 Nitro+ OC 8GB
  • Gigabyte GeForce GTX 1060 G1 Gaming 6GB
  • Sapphire Radeon RX 480 Nitro+ OC 4GB
  • Aorus Radeon RX 570 4GB (OC)
  • MSI Radeon RX 570 Gaming X 4GB
  • Gigabyte GeForce GTX 1060 WindForce OC 3GB
  • Sapphire Radeon RX 470 Nitro+ OC 4GB
    • 12249
    • 11999
    • 11855
    • 11586
    • 11344
    • 11219
    • 10840
    • 10719
    • 10713
    • 10696
5000
7500
10000
12500
Score
  • Score
Overclocking - Battlefield 1
1,920 x 1,080, DX12, 'Ultra' settings
    • 59
    • 65
    • 59
    • 64
    • 58
    • 64
    • 57
    • 63
    • 57
    • 62
    • 55
    • 60
    • 54
    • 60
    • 54
    • 59
    • 53
    • 60
    • 37
    • 41
20
30
40
50
60
70
Frames Per Second
  • Minimum
  • Average
Overclocking - The Witcher 3: Wild Hunt
1,920 x 1,080, DX11, 'Ultra' settings (HairWorks off)
    • 56
    • 63
    • 55
    • 63
    • 55
    • 61
    • 53
    • 61
    • 52
    • 59
    • 52
    • 58
    • 50
    • 56
    • 50
    • 56
    • 49
    • 56
    • 49
    • 55
20
30
40
50
60
70
Frames Per Second
  • Minimum
  • Average
